advice
14 years 2 days before #22821 by manual-mecanica
Council published by Manual-Mecanica
Hello everyone. I have a problem with the recipient displacement, clutch (when you step on the pedal a squeak is heard). Why do you?
I have two doubts:
A = What enters the arrow 1, or what does it come out?
B = What is done by arrow 2 or what is it?
Thanks in advance
14 years 1 day before #22852 by manual-mecanica
Manual-Mecanica Response on the topic Re: Council
If you listen to the noise inside the car, it is lack of greasing on the pedal. If it is outside it is the dryness of the pushing bearing (it does not give more importance) (within the clutch hole you never throw oil or fat this would spoil the clutch and you would have to replace it).
By arrow 1, the liquid that sends the clutch pedal pump, this with enough pressure to act the clutch.
By arrow 2, it is the drainage or bleeding screw of the circuit, so that the circuit does not have a single drop of air, if the pedal would not be made and the marches would not enter.
13 years 11 months before #23016 by manual-mecanica
Thank you very much ... Puts71 ... I stay calmer, because I have been spinning for a long time and I was very worried, ... in a size they advised me to change the full clutch kit and .... Total ... € 750.
That can be done to remove the dryness of the pushing bearing, because the screech that does it is annoying.
Greetings and thanks
13 years 11 months before #23023 by manual-mecanica
The truth is that you cannot do anything, if the noise is from the bearing you have to take the box and change the clutch kit. All you can do is wait for it to be more annoying and then make the investment. Ask for a budget in more than one site, which sometimes would surprise you the difference between several workshops.
13 years 11 months before #23025 by manual-mecanica
hello good afternoon and check if wears a pilot bus
