Golf IV TDI 1.9 110 CV Motor Ahv Much Smoke
14 years 2 weeks before #22484 by manual-mecanica
Golf IV TDI 1.9 110 CV Motor Ahv Much Smoke Published by Manual-Mecanica
Well, I have a golf that I have changed the heater proven the cable and nothing starts me a lot of white smoke and I stop
14 years 2 weeks before #22491 by manual-mecanica
Manual-Mecanica Answer on the Re: Golf IV TDI 1.9 110 hp Ahv Mother Smoke
The white smoke is water pre -firm in the combustion camera, now the important thing is to see where you may be contaminated, or a fault of the butt joint, it would be good to measure cold compression to your vehicle to rule out
14 years 2 weeks before #22492 by manual-mecanica
If it does not start, you have no more compression you should have minimum 19 kilos
14 years 2 weeks before #22495 by manual-mecanica
I agree but it only does it in hot cold, the cylinder head and button are less than a year since it breaks a hydraulic roller and the new one also put it in the clut No engine cleaned the admission collector that had Carbonilla has a great loss of power since I think it can be the turbo or the intercooler when breaking the valve this waterlogging of oil, I do not tell me that I throw it and take a new one but it is that I have a lot of love. all the best
14 years 2 weeks before #22504 by manual-mecanica
Friend you have a simple test buys an oil additive, of these that cut the smoke that actually increases the viscosity of the oil and tests both the start in the morning and the fiber of the vehicle, if the two things are improved, you have rings problems, if nothing happens, the impressive spark plugs happens and if it does not work it is already the problem of the injectors or the pump.
