Automatic Swift 1.6 Motor Start
14 years 3 weeks before #22124 by manual-mecanica
Automatic Swift 1.6 Motor Start published by Manual-Mecanica
I have an automatic Swift 1.6 vehicle, which turned on cold and hard 5 minutes on and turned off and did not turn on the engine again.
Check spark plugs and start 1 is burning and the remaining 3 soaks gasoline, but the four spark plugs have a distributor's current and the coil is working properly.
Check the two boxes of internal and external fuses but there is none open,
I would appreciate that please give me a light in this regard, the engine has six months repaired, but it is as if they did not make internal combustion the spark plugs.
14 years 3 weeks before #22135 by manual-mecanica
Manual-Mecanica response on the Re: Swift 1.6 automatic motor start
First of all, good night try to change the spark plugs because you can leave the coil and distributor but from the spark plug so that there are no there and my enters are enchunbada not to turn on because the engine is drowned.
14 years 3 weeks before #22140 by manual-mecanica
I test it, he says fried since he is very right with the spark plugs, but if they repaired it to you recently I imagined that they changed them, you can have a problem with the injectors or of comprehensive, I first check the spark plugs, then the compression and finally the injectors that are not dripping or open, lucky
14 years 3 weeks before #22178 by manual-mecanica
Hello
the spark plugs are not bad, they are not arriving from the distributor, clean the interior of the distributor and check that is not broken, because there may be a fugo, the terminals of the distributor's lid and check that the spark plug cables are not cut, although I believe that the failure is or in the distributor's lid, or in the coil.
Good luck
tell us that it was
14 years 3 weeks before #22207 by manual-mecanica
Check the distributor lid and that's fine, clean the contacts of the spark and lid rotor, but do not turn on the car, the coil is throwing a good spark; The spark plugs are reaching a good load of the distributor.
