Antipolution
14 years 1 month before #21526 by manual-mecanica
Antipolution published by Manual-Mecanica
Good evening, I am new in this forum, I have a Peugeot 307 2008 and on the board I take the message "Failure Antipolucion system", I do not know what else to do the spark plugs, gas pump stack, oil change, air filter, gosoline and oil filter and nothing. Help me please ..
14 years 1 month before #21567 by manual-mecanica
Manual-Mecanica Response on the Re: Antipolution
Hello friend, it controls the Lambda probe and the catalyst, but the most effective thing is that you take it to scan to have a better orientation, tell us how you go, greetings.:)
14 years 1 month before #21631 by manual-mecanica
Indeed, it is best to scare to discard, success!
14 years 3 weeks before #22132 by manual-mecanica
Ok friend I did what you told me send it to Scanaer and it is the oxygen sensor that must now be replaced where this sensor is located in the Peugeot 307 can I buy the piece and myself changing it is very fat?
thank you.
14 years 3 weeks before #22163 by manual-mecanica
The main oxygen sensor is located between the exhaust multiple and the catalytic converter, the secondary oxygen sensor is after the catalytical converter.
In general, the one fails is the primary, you can locate it, remove it and change it yourself, the only thing is that you buy it.
Greetings
