Problems with my Chevrolet cavalier
14 years 3 months before #20221 by manual-mecanica
Problems with my Chevrolet cavalier published by Manual-Mecanica
Good afternoon to all the users of this page I am writing to you because I have a problem with my cavalier ... I lost the keys on one occasion and changed the suichera the previous keys had no chip or anything and those that I mount new either, the car was shot I rolling finely a couple of months later I went out and I did not want to turn on any more ... and turn on to me on the board a red light with a lock?
Thanks for your help ...
14 years 2 months before #20562 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with my Chevrolet Cavalier
The Cavalier does not use chip in the key but a sensor in the cylinder that must be programmed when changing.
You do not indicate if the light on the board (Theft system) is fixed or blinks. In this last case you must schedule it.
In several forums they indicate different methods but the most common is as follows:
Try to turn on the engine (it will not light) and then leave the key in a march position, do not pass it to OFF
Wait 10 minutes to the light stopping to flash, it will stay fixed
wait 10 minutes with the fixed light until it turns off
passes the key to the PSocion of Loop
13 years 9 months before #25303 by manual-mecanica
Thanks friend I worked B)
13 years 9 months before #25365 by manual-mecanica
Earfidel you can post this in the section of known mechanical failures for me to leave it filed for when they ask again this failure so it is easier to find the solution if no one responds, thanks in advance.
13 years 9 months before #25372 by manual-mecanica
Always to order. I already uploaded it to the section of known mechanical problems.
