Abnormal water consumption
14 years 6 months before #17955 by manual-mecanica
Abnormal water consumption published by manual-mecanica
I have a 2002 Hyundai Accent in almost perfect operation, for 5 years I have noticed that it consumes or evaporates a lot of water in the cooling system (radiator or pipes). I have performed all kinds of repairs and even replaced by new engine packaging because the most common (according to the mechanic).
I have performed leak test, and you don't have them, there is also no heating signal in the temperature meter.
When evaluating through computer, it does not give any fault code.
Some of the friends of the forum can give me some hypothesis, because my fear is that in one of the outputs the engine may burn.
14 years 6 months before #17959 by manual-mecanica
Manual-Mecanica response on the Re: abnormal water consumption
Good afternoon, would I appreciate that you will tell a little more about the problem: the hoses are inflated? Does not dismiss liquid by escape pipe? There are no refrigerant traces on the car's floor? etc Maybe performing a thorough cleaning of the engine and then checking again when starting it is the leak.
14 years 6 months before #17975 by manual-mecanica
It is true what Ege says, the water does not disappear greatly, somewhere it should be or fall, in some opportunities these losses are by water stamps and how they are mounted on the block are dry almost immediately and not noticed, or some hose and falls to the escape without notar, there to be carefully inspect.
14 years 6 months before - 14 years 6 months before #17989 by manual-mecanica
I thank you for support, because I have changed all the visible hoses, and even the water pump for believing that they failed. There is no refrigerant brand if there were escape from the engine butt or block. I have kept it on and elevated for 20 minutes and there are no leaks. However, the replacement deposit is emptied.
Last edition: 14 years 6 months before by .
14 years 6 months before #18007 by manual-mecanica
Good
watching your problem comes to my mind that I had a corsa
and something similar happened to me that looks at you when I looked at him with Che started I didn't see anything, the problem was when you walked more revolutions the circuit took pressure and one of the sleeves at the exit of the pump was bitten but was walking.
accelerated when you look to see if it drips somewhere
luck
