Citroen C2 Climatizer Fans doesn't work
11 years 10 months before #42751 by manual-mecanica
Very good, I find the next problem, I turn on the C2 and when I start the air conditioner, no air comes out, the compressor is started. You know it can be. I have read in other forums that can be the resistance of the air driver.
I would appreciate if someone has happened to him, the same thing tells me something.
Thank you so much.
11 years 10 months before #42761 by manual-mecanica
Good compa. If the C2 is multiplexed you must take it to a workshop. Otherwise check the Blower, Switch fuse, or the resistance that is inserted in Blower himself. You must keep in mind that switch signals to the Blower are negative.
In theory the resistance of the Blower looks like this
www.google.co.cr/url?sa=i&rct=j&q=&esrc=...ust=1375669854748140
Tiempo de carga de la página: 0.180 segundos
