Regulatory right lights are not. Picasso
12 years 1 month before #41514 by manual-mecanica
Regulatory right lights are not. Picasso published by Manual-Mecanica
:( Hello, current does not reach right position lights, my Xsara Picasso does not match fuse box with manual, I checked one and are fine. Someone can help me please, it is 1.6 2011 and I can't find the fuses on the network. I attach the boxes if someone has the identification. Thank you.
12 years 1 month before #41516 by manual-mecanica
Manual-Mecanica response on the subject regulatory right lights are not. Picasso
I give you a solution if you do not get dough (-) a cable to the chassis, if you do not reach (+) a cable to the positive of the other position bulb. The bad if the car reflects in the box as a molten bulb.
It can be fuse or can be rel. Some cars carry a light of lights for each side or some broken cable and go crazy looking.
12 years 1 month before #41523 by manual-mecanica
Thanks for the "Igryo" breath, it does not arrive (+), hope it is fuse which one?
