Toyota Hilux 3.0 D4D
11 years 10 months before #43277 by manual-mecanica
Toyota Hilux 3.0 D4D published by Manual-Mecanica
Hello friends, I have a Hilux 3.0 4x4, the truck is manual and when it goes down, it makes a strange noise, a Ric Ric Ric ... or something like that, it doesn't matter the change in which it is, it does the same; When stepping on the clutch, the sound is removed (he has always had the sound), I hope you know something. All the best.
11 years 10 months before #43281 by manual-mecanica
Manual-Mecanica response on the topic Toyota Hilux 3.0 D4D
Hello good night that noise is the collar balinera you have to disassemble the box to change it must take into account check the wear of the disc and the press depending on the km that the mobile car has also verify if the pressure accompanulating has no leakage or makes noise
I hope it serves you
11 years 10 months before #43282 by manual-mecanica
If it is a truck, you could have problems with the cardan crusets, the box sounds the same if you go straight in a march or only in the example you mentioned us
